Turns on SNMP authentication trap support.
N/A.
Changes are synchronized between the show switch management command and SNMP get.
To view if SNMP authentication traps are being sent from the switch, use the show management command. The show management command displays information about the switch including the enabled/disabled state of SNMP traps being sent.
The following command enables SNMP authentication trap support on the switch:
enable snmp authentication-traps
This command was first available in version 33.1.1.
